×Even though it is documented here
https://confluence.atlassian.com/bamboo/project-level-build-resources-1071825278.html
My project settings page only has "Variables" in Shared Resources, and there is nothing about the "Shared Credentials" as described in the docs..
Hi @Daniel Varela Santoalla, a Data Center license is necessary to use all the elements of the Project level build resources feature https://confluence.atlassian.com/bambooreleases/bamboo-8-0-release-notes-1189793878.html
Ok thanks, I suspected that. However it is not clear *at all* in the documentation page referred to above.. The documentation read "Data Center and Server" and there is no mention to the fact that this is a Data Center only feature..
