Hi Dear supporter,
In the following pieces of building log, you can see that docker run command failed and tell me why it failed.
Thanks!
build 11-Nov-2024 05:50:03 Checking if its a bamboo build
build 11-Nov-2024 05:50:03 Running Linux build on Bamboo Agent
build 11-Nov-2024 05:50:03 Executing: docker run --rm --name 2d650ee8-344b-43d1-a67e-1408da700237 -e bamboo_agentId="552763395" -e bamboo_agentWorkingDirectory="/app/bamboo-home/xml-data/build-dir" -e bamboo_AM_DOCKERHUB_DOCKE_PASSWORD="********" -e bamboo_AM_DOCKERHUB_DOCKER_USER="mcmillan.goyal@honeywell.com" -e bamboo_AM_GH_TOKEN_SECRET="********" -e bamboo_AM_TWISTLOCK_SAASOPS_ACCESSKEYID="b2c7de7e-eeab-439d-ae75-db8f6cb145e4" -e bamboo_AM_TWISTLOCK_SAASOPS_SA_NAME="sv_automate_global" -e bamboo_AM_TWISTLOCK_SAASOPS_SECRETKEY="********" -e bamboo_AM_TWISTLOCK_SAASOPS_SERVERURL="https://us-west1.cloud.twistlock.com/us-4-161030324" -e bamboo_ARTIFACTORY_API_PASSWORD="********" -e bamboo_BINARY_DEPLOY_URL_STABLE="https://artifactory-na.honeywell.com/artifactory/f1-webs-ip-som-qnx-niagara-deploy-generic-stable-local" -e bamboo_BINARY_DEPLOY_URL_UNSTABLE="https://artifactory-na.honeywell.com/artifactory/f1-webs-ip-som-qnx-niagara-deploy-generic-unstable-local" -e bamboo_build_working_directory="/app/bamboo-home/xml-data/build-dir/OBYIYVKG-FZMDRUDF-JOB1" -e bamboo_buildFailed="false" -e bamboo_buildKey="OBYIYVKG-FZMDRUDF-JOB1" -e bamboo_buildNumber="156" -e bamboo_buildPlanName="F1_Webs_IP_SOM_QNX_Niagara - F1_Webs_IP_SOM_QNX_Niagara - Build and Package" -e bamboo_buildResultKey="OBYIYVKG-FZMDRUDF-JOB1-156" -e bamboo_buildResultsUrl="https://acsbamboo.honeywell.com/browse/OBYIYVKG-FZMDRUDF-JOB1-156" -e bamboo_buildTimeStamp="2024-11-11T05:40:37.822Z" -e bamboo_capability_build_agent_dockerversion="latest" -e bamboo_capability_build_agent_no="nd53" -e bamboo_capability_build_agent_os="linux" -e bamboo_capability_build_agent_size="small" -e bamboo_capability_build_farm="azure" -e bamboo_capability_pssbmagent_projectname="AndroidLicensing" -e bamboo_capability_system_builder_command_Findbugs="C:\AgentTools\findbugs-2.0.3\bin\findbugs.bat" -e bamboo_capability_system_docker_executable="/usr/bin/docker" -e bamboo_capability_system_git_executable="/usr/bin/git" -e bamboo_COVERITY_PASSWORD="********" -e bamboo_COVERITY_PROJECTNAME="[HCE]-HBT-CONNECTEDBUILDING-NONE-F1WEBSIPSOMQNXNIAGARA-F1WEBSIPSOMQNXNIAGARA" -e bamboo_COVERITY_SERVERPORT="8080" -e bamboo_COVERITY_SERVERURL="coverity.swtools.honeywell.com" -e bamboo_COVERITY_STREAMNAME="[HCE]-HBT-CONNECTEDBUILDING-NONE-F1WEBSIPSOMQNXNIAGARA-F1WEBSIPSOMQNXNIAGARA-MASTER" -e bamboo_COVERITY_USERNAME="hbt-connectedbuilding-none-f1websipsomqnxniagara-sa" -e bamboo_dependenciesDisabled="false" -e bamboo_ENCRYPT_PASSWORD="********" -e bamboo_git_cache_directory="/app/bamboo-home/xml-data/build-dir/_git-repositories-cache" -e bamboo_GITHUB_TOKEN_SECRET="********" -e bamboo_JRE_VERSION="1.8.0.221" -e bamboo_ManualBuildTriggerReason_userName="h575199" -e bamboo_NRE_CONFIG_VERSION="4.7.110.32.165" -e bamboo_NRE_CORE_VERSION="4.7.110.32.20" -e bamboo_plan_storageTag="plan-395313700" -e bamboo_planKey="OBYIYVKG-FZMDRUDF" -e bamboo_planName="F1_Webs_IP_SOM_QNX_Niagara - F1_Webs_IP_SOM_QNX_Niagara" -e bamboo_planRepository_1_branch="F1_Prj_Common_NPSDK" -e bamboo_planRepository_1_branchDisplayName="F1_Prj_Common_NPSDK" -e bamboo_planRepository_1_branchName="F1_Prj_Common_NPSDK" -e bamboo_planRepository_1_name="F1_Webs_IP_SOM_QNX_Niagara" -e bamboo_planRepository_1_previousRevision="f074fb3d0e1937ba4ad06f0f6e7c1bfbd58c8381" -e bamboo_planRepository_1_repositoryUrl="ssh://git@bitbucket.honeywell.com:7999/f1ct/f1_webs_ip_som_qnx_niagara.git" -e bamboo_planRepository_1_revision="f074fb3d0e1937ba4ad06f0f6e7c1bfbd58c8381" -e bamboo_planRepository_1_type="bbserver" -e bamboo_planRepository_1_username="" -e bamboo_planRepository_branch="F1_Prj_Common_NPSDK" -e bamboo_planRepository_branchDisplayName="F1_Prj_Common_NPSDK" -e bamboo_planRepository_branchName="F1_Prj_Common_NPSDK" -e bamboo_planRepository_name="F1_Webs_IP_SOM_QNX_Niagara" -e bamboo_planRepository_previousRevision="f074fb3d0e1937ba4ad06f0f6e7c1bfbd58c8381" -e bamboo_planRepository_repositoryUrl="ssh://git@bitbucket.honeywell.com:7999/f1ct/f1_webs_ip_som_qnx_niagara.git" -e bamboo_planRepository_revision="f074fb3d0e1937ba4ad06f0f6e7c1bfbd58c8381" -e bamboo_planRepository_type="bbserver" -e bamboo_planRepository_username="" -e bamboo_repository_395509873_branch_name="F1_Prj_Common_NPSDK" -e bamboo_repository_395509873_git_branch="F1_Prj_Common_NPSDK" -e bamboo_repository_395509873_git_repositoryUrl="ssh://git@bitbucket.honeywell.com:7999/f1ct/f1_webs_ip_som_qnx_niagara.git" -e bamboo_repository_395509873_git_username="" -e bamboo_repository_395509873_name="F1_Webs_IP_SOM_QNX_Niagara" -e bamboo_repository_395509873_previous_revision_number="f074fb3d0e1937ba4ad06f0f6e7c1bfbd58c8381" -e bamboo_repository_395509873_revision_number="f074fb3d0e1937ba4ad06f0f6e7c1bfbd58c8381" -e bamboo_repository_branch_name="F1_Prj_Common_NPSDK" -e bamboo_repository_git_branch="F1_Prj_Common_NPSDK" -e bamboo_repository_git_repositoryUrl="ssh://git@bitbucket.honeywell.com:7999/f1ct/f1_webs_ip_som_qnx_niagara.git" -e bamboo_repository_git_username="" -e bamboo_repository_name="F1_Webs_IP_SOM_QNX_Niagara" -e bamboo_repository_previous_revision_number="f074fb3d0e1937ba4ad06f0f6e7c1bfbd58c8381" -e bamboo_repository_revision_number="f074fb3d0e1937ba4ad06f0f6e7c1bfbd58c8381" -e bamboo_resultsUrl="https://acsbamboo.honeywell.com/browse/OBYIYVKG-FZMDRUDF-JOB1-156" -e bamboo_SAASAIRTIME_FREQUENTRELEASE_ARTIFACTORY_PASSWORD="********" -e bamboo_SAASAIRTIME_FREQUENTRELEASE_ARTIFACTORY_USER="sv_zfwrlpxc_user" -e bamboo_shortJobKey="JOB1" -e bamboo_shortJobName="Build and Package" -e bamboo_shortPlanBranchName="" -e bamboo_shortPlanKey="FZMDRUDF" -e bamboo_shortPlanName="F1_Webs_IP_SOM_QNX_Niagara" -e bamboo_SONAR_API_PASSWORD="********" -e bamboo_sonar_bamboo_password="********" -e bamboo_SONAR_PROJECTKEY="FZMDRUDF" -e bamboo_SONAR_SERVERURL="https://sonarqube.honeywell.com" -e bamboo_tmp_directory="/app/bamboo-home/temp" -e bamboo_working_directory="/app/bamboo-home/xml-data/build-dir/OBYIYVKG-FZMDRUDF-JOB1" -v /data/cache/maven_local_cache:/home/sv_bamboo_agent/.m2 -v /data/cache/npm_local_cache:/home/sv_bamboo_agent/npm_local_cache -v /data/cache/sonar_local_cache:/home/sv_bamboo_agent/.sonar -v /data/bamboo/build-dir/OBYIYVKG-FZMDRUDF-JOB1:/repo -v /var/run/docker.sock:/var/run/docker.sock --mac-address 00:00:00:00:00:20 -t beats-now-docker-stable-local.artifactory-na.honeywell.com/qnx_bsp_environment_docker:latest -Verbosity Diagnostic error 11-Nov-2024 05:50:03 docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: exec: "build.sh": cannot run executable found relative to current directory: unknown.
build 11-Nov-2024 05:50:03 Exit code is 125
@Wang Xiujun welcome to the Atlassian community
build.sh
script specified in your Dockerfile or docker run
command. This typically stems from one of the following issues:
