how to launch remote agent in bamboo without executing remote agent installer jar on agent.. Is there any other way to do this?
Hello Yogita Dolas,
First, you must install the remote agent by running the command:
java -Dbamboo.home=/path/to/bamboo-remote-agent -jar atlassian-bamboo-agent-installer-X.X-SNAPSHOT.jar BAMBOO_SABE_URL/agentServer/
Reference: https://confluence.atlassian.com/display/BAMBOO/Bamboo+remote+agent+installation+guide
After the agent is installed, you can start the agent by running:
cd /path/to/bamboo-remote-agent ./bin/bamboo-agent.sh start
Rafael
Atlassian
