build 19-Jul-2022 09:00:22 2022-07-19 09:00:22,635 INFO [main] com.bizrule.BusinessRules: validateMailingAddressEffectiveDates method : OrchId = 0; TimeTaken : 0(ms)
build 19-Jul-2022 09:00:22 2022-07-19 09:00:22,653 INFO [main] com.bizrule.BusinessRules: validateMailingAddressEffectiveDates method : OrchId = 0; TimeTaken : 0(ms)
build 19-Jul-2022 09:00:22 2022-07-19 09:00:22,672 INFO [main] com.bizrule.BusinessRules: handleInputRequestForRemitanceAddressCheck method : OrchId = 0; TimeTaken : 0(ms)
build 19-Jul-2022 09:00:22 2022-07-19 09:00:22,690 INFO [main] com.bizrule.BusinessRules: setAcceptingPatient method : OrchId = 0; TimeTaken : 0(ms)
build 19-Jul-2022 09:00:22 2022-07-19 09:00:22,710 INFO [main] com..bizrule.BusinessRules: setAcceptingPatient method : OrchId = 0; TimeTaken : 1(ms)
build 19-Jul-2022 09:00:22 2022-07-19 09:00:22,729 INFO [main] com.bizrule.BusinessRules: setAcceptingPatient method : OrchId = 0; TimeTaken : 1(ms)
build 19-Jul-2022 09:01:22 2022-07-19 09:01:22,770 WARN [main] org.hibernate.engine.jdbc.spi.SqlExceptionHelper: SQL Error: 17002, SQLState: 08006
build 19-Jul-2022 09:01:22 2022-07-19 09:01:22,771 ERROR [main] org.hibernate.engine.jdbc.spi.SqlExceptionHelper: IO Error: The Network Adapter could not establish the connection
build 19-Jul-2022 09:01:22 [ERROR] Tests run: 46, Failures: 0, Errors: 8, Skipped: 0, Time elapsed: 554.529 s <<< FAILURE! - in com.bizrule.BusinessRulesTest
build 19-Jul-2022 09:01:22 [ERROR] TestvalidateAtypicalRegistrationForARScenario2 Time elapsed: 60.586 s <<< ERROR!
build 19-Jul-2022 09:01:22 org.springframework.dao.DataAccessResourceFailureException: Unable to acquire JDBC Connection; nested exception is org.hibernate.exception.JDBCConnectionException: Unable to acquire JDBC Connection
Hi @Surya Chowdary :
Please, check with network administrator team to validate connection between server and database.
@Mahesh Shinde Thank you. The issue is resolved.
it was a firewall connection issue between the Bamboo agent and DB.
