×Tried to add a linked repository to Bamboo, where the git repository is on another machine.
Other remote repositories on the same bamboo server work.
The real URL is
ssh://git@bitbucket.renalregistry.nhs.uk:7999/inf/housekeeping.git
And I get these errors:
Unable to detect changes
Occurred: 26 Jul 2017, 2:58:50 PM
com.atlassian.bamboo.plugins.git.GitCommandException: command 'C:\Program Files (x86)\Git\cmd\git.exe' ls-remote ssh://9447c727-f065-4b1f-985c-c0c037ea4e96@127.0.0.1:49266/inf/housekeeping.git failed with code 128. Working directory was [.]., stderr: Warning: Permanently added '[127.0.0.1]:49266' (RSA) to the list of known hosts. Repository not found The requested repository does not exist, or you do not have permission to access it. fatal: Could not read from remote repository. Please make sure you have the correct access rights and the repository exists. at com.atlassian.bamboo.plugins.git.GitCommandProcessor.runCommand(GitCommandProcessor.java:720) at com.atlassian.bamboo.plugins.git.GitCommandProcessor.getRemoteRefs(GitCommandProcessor.java:508) at com.atlassian.bamboo.plugins.git.NativeGitOperationHelper.lambda$getRemoteRefs$0(NativeGitOperationHelper.java:628) at com.atlassian.bamboo.util.CallableResultCache$1.load(CallableResultCache.java:43) at com.atlassian.bamboo.util.CallableResultCache$1.load(CallableResultCache.java:38) at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3527) at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2319) at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2282) at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2197) at com.google.common.cache.LocalCache.get(LocalCache.java:3937) at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:3941) at com.google.common.cache.LocalCache$LocalLoadingCache.get(LocalCache.java:4824) at com.atlassian.bamboo.collections.AlwaysInvalidatingCacheDecorator.get(AlwaysInvalidatingCacheDecorator.java:71) at com.atlassian.bamboo.collections.AlwaysInvalidatingCacheDecorator.getUnchecked(AlwaysInvalidatingCacheDecorator.java:145) at com.atlassian.bamboo.util.CallableResultCache.call(CallableResultCache.java:164) at com.atlassian.bamboo.plugins.git.NativeGitOperationHelper.getRemoteRefs(NativeGitOperationHelper.java:639) at com.atlassian.bamboo.plugins.git.NativeGitOperationHelper.resolveBranch(NativeGitOperationHelper.java:576) at com.atlassian.bamboo.plugins.git.NativeGitOperationHelper.obtainLatestRevision(NativeGitOperationHelper.java:682) at com.atlassian.bamboo.plugins.git.v2.GitChangeDetector.collectChanges(GitChangeDetector.java:74) at com.atlassian.bamboo.plugins.git.v2.GitChangeDetector.collectChangesSinceRevision(GitChangeDetector.java:50) at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectionChangesWithRetry(DefaultChangeDetectionManager.java:559) at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.lambda$createBuildRepositoryChanges$0(DefaultChangeDetectionManager.java:440) at com.atlassian.bamboo.variable.CustomVariableContextImpl.withVariableSubstitutor(CustomVariableContextImpl.java:221) at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectChangesSinceLastBuildInternal(DefaultChangeDetectionManager.java:385) at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectChangesSinceRevisions(DefaultChangeDetectionManager.java:310) at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectChangesSinceRevisions(DefaultChangeDetectionManager.java:193) at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectChangesSinceLastBuildIfTriggered(DefaultChangeDetectionManager.java:131) at com.atlassian.bamboo.v2.trigger.ChangeDetectionListenerAction.testIfBuildShouldStart(ChangeDetectionListenerAction.java:114) at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$3.call(PlanExecutionManagerImpl.java:509) at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$3.call(PlanExecutionManagerImpl.java:492) at io.atlassian.util.concurrent.ManagedLocks$ManagedLockImpl.withLock(ManagedLocks.java:293) at com.atlassian.bamboo.plan.PlanExecutionLockServiceImpl.lock(PlanExecutionLockServiceImpl.java:85) at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.doWithProcessLock(PlanExecutionManagerImpl.java:783) at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.startConditionalBuild(PlanExecutionManagerImpl.java:491) at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.start(PlanExecutionManagerImpl.java:565) at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.start(PlanExecutionManagerImpl.java:582) at com.atlassian.bamboo.plan.DelegatingPlanExecutionManager.start(DelegatingPlanExecutionManager.java:95) at com.atlassian.bamboo.plan.NonBlockingPlanExecutionServiceImpl$4.startPlanExecution(NonBlockingPlanExecutionServiceImpl.java:234) at com.atlassian.bamboo.plan.NonBlockingPlanExecutionServiceImpl$4.lambda$call$0(NonBlockingPlanExecutionServiceImpl.java:220) at com.atlassian.bamboo.util.CacheAwareness$3.call(CacheAwareness.java:159) at com.atlassian.bamboo.util.CacheAwareness$3.call(CacheAwareness.java:155) at com.atlassian.bamboo.util.CacheAwareness.withValuesOlderThanTimestampReloaded(CacheAwareness.java:188) at com.atlassian.bamboo.util.CacheAwareness.withValuesOlderThanTimestampReloaded(CacheAwareness.java:154) at com.atlassian.bamboo.util.CacheAwareness.withValuesOlderThanTimestampReloaded(CacheAwareness.java:219) at com.atlassian.bamboo.plan.NonBlockingPlanExecutionServiceImpl$4.call(NonBlockingPlanExecutionServiceImpl.java:219) at com.atlassian.bamboo.plan.NonBlockingPlanExecutionServiceImpl$4.call(NonBlockingPlanExecutionServiceImpl.java:202) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at com.atlassian.bamboo.utils.BambooRunnables$1.run(BambooRunnables.java:51) at com.atlassian.bamboo.security.ImpersonationHelper.runWith(ImpersonationHelper.java:31) at com.atlassian.bamboo.security.ImpersonationHelper.runWithSystemAuthority(ImpersonationHelper.java:20) at com.atlassian.bamboo.security.ImpersonationHelper$1.run(ImpersonationHelper.java:52) at java.lang.Thread.run(Thread.java:745)
TIA
Hi Roger,
You stated The other remote repos on the same server work.
This could really be any sort of connection error between Bamboo and Bitbucket Server. I would try running the git command manually from the Bamboo server to see if the error appears there as well.
Branden
They're on the same bitbucket host.
No restrictions set.
I'm using the same public key credentials across all the components.
I've used git from bamboo server to checkout the code onto the server. (but not using the above c/l, just a standard git clone)
The original repositories had their git origins reset in a task in the Bamboo build scripts.
(This new repo is supposed to be a secondary module containing housekeeping scripts which the original ones will use. It should only ever be cloned and used.)
Regards, Roger
