Hi James, keep in mind that the solution proposed in that article is referring to Stash (old version of Bitbucket Server) so if you're using Bitbucket Server, that will not help. In your case you should try:
$ cd /var/atlassian/application-data/bitbucket
$ chown -R atlbitbucket:atlbitbucket *
Which is documented in this other article.
Let us know if this worked for you.
Best regards,
Ana
Guys, i do have the same issue. am using Ubuntu16.4. Help me with the fix
