Bitbucket pipelines authorization denied by plugin pipelines
Marian Terchila
September 28, 2022
I am currently trying to build a bitbucket pipeline which is supposed to run a docker-compose file to test a microservice before deployment. The docker compose file is supposed to build my microservice image and run it.
This all seems to work fine locally, however, when I move things to the pipeline I constantly keep getting this error:
#1 [internal] booting buildkit
#1 pulling image moby/buildkit:buildx-stable-1
#1 pulling image moby/buildkit:buildx-stable-1 2.4s done
#1 creating container buildx_buildkit_default 0.0s done
#1 ERROR: Error response from daemon: authorization denied by plugin pipelines: --privileged=true is not allowed
 > [internal] booting buildkit:
Dockerfile
FROM node:12-alpine
WORKDIR /app/playground
RUN npm install npm@7.1.2
RUN rm -rf /usr/local/lib/node_modules/npm
RUN mv node_modules/npm /usr/local/lib/node_modules/npm
COPY package.json package-lock.json ./
RUN npm ci
COPY . .
CMD [ "npm", "run", "start" ]
docker-compose.yml
version: "3"
services:
  playground:
    build: .
    ports:
      - 9111:9111
    env_file:
      - ./envs/test.env
I understand that bitbucket pipelines have some mechanism to prevent certain operations from executing for security reasons, but as far as I am aware I am not doing that here.
Any idea of how I could possibly fix this error?
13 votes
Rich Kalsky
June 2, 2023
I too was getting this error:
+ docker build --build-arg SSH_PRIVATE_KEY -t $IMAGE_NAME .
WARNING: No output specified with docker-container driver. Build result will only remain in the build cache. To push result image into registry use --push or to load image into docker use --load
#1 pulling image moby/buildkit:buildx-stable-1 3.4s done
So I added the "export DOCKER_BUILDKIT=0" and that allowed it to build, BUT it says it's deprecated. So now what do I need to do to future-proof my pipeline?
bash: warning: command substitution: ignored null byte in input
DEPRECATED: The legacy builder is deprecated and will be removed in a future release.
BuildKit is currently disabled; enable it by removing the DOCKER_BUILDKIT=0
environment-variable.
8 votes
wrc92
October 25, 2022
I was able to get a docker-compose build working by adding this at the beginning of my script:
- export DOCKER_BUILDKIT=0
3 votes
Stephan Hohn February 14, 2023
Added
DOCKER_BUILDKIT=0
as build/repository variable
Sean
June 6, 2023
Adding export DOCKER_BUILDKIT=0 to the build pipeline resolved my issue but as already mentioned in a previous comment, the legacy builder is deprecated and will be removed eventually.
More information about BuildKit can be found in the Docker Documentation.
Patrick Nelson
Check out Theodora's solution (from Atlassian) in this answer here: https://community.atlassian.com/t5/Bitbucket-questions/Re-Docker-build-failing-for-buildkit-with-error-authori/qaq-p/2381177/comment-id/94515#M94515
Basically, another good solution might be to update the $PATH to point to /usr/bin so you don't have to manually disable BuildKit (especially useful if the legacy builder ever ends up going away, possibly breaking things again).
Thanakorn Khuntum
June 6, 2023
OMG
add
in bitbucket-pipelines.yml
- docker build -t ...
it working for me
Thanakorn Khuntum
June 6, 2023
I had the same problem 14 days ago still working.
Daniel Engelhardt
February 14, 2024
For anybody who stumbles upon this, my issue was that I was trying to mount a named volume to one of my containers, which apparently isn't allowed in bitbucket.
Takudzwa Shumbamhini
July 6, 2023
Hi all
Neither adding export DOCKER_BUILDKIT=0 nor editing $PATH in bitbucket pipelines worked for me. Anyone has a solution outside of these? I tried adding either one, and both of them at the same time and still did not resolve the problem.
- echo "BuildKit ${DOCKER_BUILDKIT}"
- export USR=/usr/bin
- export PATH=$USR:$PATH
- echo "Path ${PATH}"
But im still getting
12
13
#1 pulling image moby/buildkit:buildx-stable-1 2.8s done
14
#1 creating container buildx_buildkit_default done
15
16
17
18
19
20
Andreas F
June 6, 2023
up
Fabio Parlascino
June 6, 2023
Suddenly having the same issue.
Tuomas Pesola June 5, 2023
Same here. Any suggestions?
Mark Bence Kiss
June 5, 2023
Same here!
Somarjun Chandolu
June 4, 2023
up
Deleted user June 2, 2023
up
Alessandro Muraro
June 1, 2023
Thanks Stephan
Alexander Prams
October 11, 2022
Thanks for the followup! I actually also resorted to building with docker build but am also running my 3 containers with docker run separately now, so I was basically rebuilding docker-compose. That was feasible for just 3 containers, but yeah.
I will try your approach as well :)
Marian Terchila
October 7, 2022
I have managed to find a working solution to this.
Instead of using build: . in your docker-compose.yml, build the image from the Dockerfile as part of the pipeline and use that image tag in your docker-compose.yml
docker-compose.yml becomes
version: "3"
services:
cases-ms:
image: cases-ms
 pipeline becomes
- step:
name: Unit tests and Snyk scan
image: alpine:3.12
runs-on:
- self.hosted
- linux
services:
- docker
script:
- apk add nodejs npm curl
- chmod +x /usr/local/bin/docker-compose
- echo //registry.npmjs.org/:_authToken=$NPM_TOKEN_READ_ONLY >> .npmrc
- docker build . -t $BITBUCKET_REPO_SLUG
Alexander Prams
September 29, 2022
I'm currently having the same error, could you resolve it?
