Problem running Gulp/Stylus from Bitbucket Pipeline
wallmanderco-jameswills
July 29, 2019
I am a complete newbie on Bitbucket Pipelines, but I am just looking to create a simple process so that just before files are pushed, the Gulp process is run and compiles all required assets before the push, which then uploads the files to our server via a webhook. I currently have the below:
pipelines: default:
step: script:
cd wp-content/themes/my-wp-theme
npm install
npm install -g gulp
npm install stylus -g
gulp
However the above is failing with the following:
Error: 'tried to require: stylus'.None found. Make sure one has been installed!
How can I get around this error? Also, the pipeline takes 2-3 mins to run! Is there any way to speed this up?
