A NoClassDefFoundError: org/w3c/dom/Element Problem
rinoux October 18, 2016
I've followed the tutorial of creating a Bitbucket plugin, when adding a dependency of pmd(whatever is 5.1.3 or 5.5.1), when 'atlas-debug', even I write nothing in the plugin project, always an error comes like:
so I add a dependency 'xml-apis' which contains the specified class, then :
LinkageError: org/w3c/dom/Element
then I exclude 'jaxen', it runs without error, but the 'pmd' could not start successfully.
Michael Heemskerk
October 18, 2016
Can you try to add an OSGI package import for the org.w3c.dom package in the Import-Package section of the bitbucket-maven-plugin in your pom.xml? That way, the plugin classloader will find the correct version of org.w3c.dom.Element that is exported by Bitbucket.
thank u, sounds useful, I am trying
rinoux October 27, 2016
You answer is really helpful, I worked it out finally.
