I want to add some fields to issues, is it possible? Or at least may be there are some extra 'hidden' fields that can be used?
If you're looking for custom fields on issues, you'll want to upgrade to using JIRA. The Bitbucket issue tracker is designed to be simple and Bitbucket doesn't have anything like this on the roadmap.
