Using the SSH_KEY of the pipe https://bitbucket.org/atlassian/scp-deploy/src/master/
is not working.
Every time I get:
scp -rp -i /opt/atlassian/pipelines/agent/ssh/id_rsa_tmp -P 22
Warning: Identity file /opt/atlassian/pipelines/agent/ssh/id_rsa_tmp not accessible: No such file or directory.
Host key verification failed.
lost connection
This is my code:
- pipe: atlassian/scp-deploy:0.3.4
variables:
USER: $SSH_USER
SSH_KEY: $SSH_DEPLOY_KEY
SERVER: $SSH_SERVER
REMOTE_PATH: '~/back-develop/docker-compose.yml'
LOCAL_PATH: 'docker-compose.yml'
DEBUG: 'true'
EXTRA_ARGS: '-P $SSH_PORT'
The `SSH_DEPLOY_KEY` is normally correct as it is working for the pipe `atlassian/ssh-run`. So it's a base64 encoding of the key that I added to my repository variables.
I am having the same issue. I do believe that the SSH_KEY being passed in is the key being used however the issue I see is that when following the instructions mentioned above on the variables and secrets doc page it advises to add the server signature to the file ~/.ssh/known_hosts.
Looking in to the logs more it looks like the container mounts the directoy
and then pulls the known hosts file from there. this is a read only dir in the parent container and only contains host keys I have added on the admin page and not in the pipelines itself
Atlassisan - how can this behaviour be overriden so that when using a custom SSH_KEY variable the correct known hosts file is also loaded?
@robin this could be because you have not added the host to the known hosts file in your bitbucket pipelines environment.
Check Step 2: Update the known hosts on this page https://support.atlassian.com/bitbucket-cloud/docs/variables-and-secrets/.
Without adding it, the ssh connection will fail because it cannot verify the remote host.
Hi @robin , could you try remove the SSH_KEY parameter and configure SSH keys from the repository settings as described here https://confluence.atlassian.com/bitbucket/use-ssh-keys-in-bitbucket-pipelines-847452940.html ?
P.S. Sorry for such a late reaction, the question fell of our radars for some reason.
I have the same issue: The `SSH_DEPLOY_KEY` is normally correct as it is working for the pipe `atlassian/ssh-run`. So it's a base64 encoding of the key that I added to my repository variables. But in atlassian/scp-deploy:0.3.12 does't work.
Same for us - it's documented as if it should work but it does not. Atlassian, can you confirm if this variable is used by this container?
