BitBucket git authentication problems after changing project name
John Roach
February 9, 2013
Hi, I just changed my project name in BitBucket. Now my git doesn't work.
When I do the;
john@johnslinuxlaptop:~/workspace/RenkoERP$ git push
Permission denied (publickey).
fatal: The remote end hung up unexpectedly
When I do the;
john@johnslinuxlaptop:~/workspace/RenkoERP$ ssh -T hg@bitbucket.org
conq: logged in as johnroach.
You can use git or hg to connect to Bitbucket. Shell access is disabled.
What might be the problem?
Stefan Saasen
February 10, 2013
Hey John,
Did you apply the name change to your local git repositroy?
What does `git remote -v` return? Does it contain the old URL for your git repository?
In that case you need to update the URL using:
git remote set-url origin URL
HTH.
Stefan
