Bitbucket-pipeline Python pandas module not found
tobi_r December 21, 2017
Hello everybody out there using Bitbucket,
In my pipeline for running a simple python script,
I get an error about the pandas module not being found:
image: python:3.5.1
pipelines:
  default:
    - step:
        script:
          - apt-get update
          - apt-get install -y python3-pandas
          - apt-get install -y python3-matplotlib
          - pip install pandas
          - pip install matplotlib
    - step:
        script:
          - cd ./src/
          - python script.py
Since I install the package which doesn't give me an error, I would actually expect it to work.
Could anyone of you point me towards additional diagnostics to run in order to pin down the problem?
Edwin Kyalangalilwa
December 21, 2017
Try installing using .. which is for python3
pip3 install pandas
tobi_r December 22, 2017
Hi Edwin,
Thanks a lot for your answer. I tried your suggestion, but the error message remains.
Edwin Kyalangalilwa
December 22, 2017
How about running the script with python3
python3 script.py
tobi_r December 24, 2017
Hi Edwin,
Thanks for your additional suggestion.
The error message does unfortunately still remain.
