Bitbucket pipeline does not start automatically after push
Dominik Filkus
March 12, 2019
I am trying to find an answer why is my pipeline does not start automatically when i push to the dev branch. My YML configuration looks like this:
image: node:11.8.0
definitions:
caches:
yarncache: /usr/local/share/.cache/yarn/v1
steps:
- step: &install
caches:
- node
- yarncache
script:
- yarn
pipelines:
branches:
dev:
- step: *install
Based on the documentation this should trigger the *install step when I push to the dev branch but unfortunately it never happen and I have to do it manually.
Thanks for your help in advance!
Dominik Filkus
May 3, 2019
Hi @davina
Thank you for your answer!
The pipelines turned on under the settings menu
I guess the problem should be around the webhooks but i cannot really find anything about how to properly configure it. What should be under the webhook menu related to pipelines? Is this automatic or need to configure something manually? I can see this, maybe it is related:
It says it is active:
No idea where that URL come from and other settings.
I can add totally new webhooks as well. Do you have any idea what should be wrong here?
Or is there any documentation about how to properly configure a webhook for pipelines if it is not automatic?
Thank you in advance!
davina
April 16, 2019
Hi @Dominik Filkus
I tested this on my own repository and it works as expected, so I'm not sure why it's not working for you?
Some things to check are:
  • Is Pipelines enabled and do you have enough minutes to run a build?
  • Are push webhooks firing correctly? You can see these in your repository settings.
Let me know if there are any other details that might help diagnose this issue.
