Bitbucket pipeline for Angular 7 build and deploy on heroku
karthik nayak
December 6, 2019
I'm trying to build and deploy to heroku. on ng build --prod its creating dist folder and copy of the angular application .this is my yml file
image: node:10.15.3
pipelines:
default:
- step:
caches: - node
script: # Modify the commands below to build your repository.
npm install
- npm test
branches:
master:
step:
script:
npm install
npm install -g @angular/cli
ng build --prod
echo "$(ls dist/)"
step:
script:
pipe: atlassian/heroku-deploy:1.1.0
variables:
HEROKU_API_KEY: 8*/****8
HEROKU_APP_NAME: ****
ZIP_FILE: file-systme
Please help
Peter Plewa
January 16, 2020
Hi @karthik nayak
What is the error you're getting?
Peter
