Bitbucket pipelines integration with AWS, using ASP.NET Core 1.1
sneuly
May 18, 2017
 I want to deploy my application to AWS elastic beanstalk , after each commit using bitbucket pipelines. I spent hours searching for more information regarding this topic. Both, on atlassian and aws documentations, there are no examples of doing it with asp.net core. Only python. All examples that I found for .net are either only for test and build (which i have done already and it works) or they are being deployed to ftp server.  So is it possible to deploy it directly to aws elastic beanstalk? If so, please provide an example. Thanks in advance.
xtjhin
May 22, 2017
Python is often included in most docker images as it's a language used for ops.
The microsoft/dotnet image has python in it
