I just received an invite for the Bitbucket Pipelines beta, psyched to try it out. I'm attempting to build Sphinx docs (and possibly MkDocs) documentation and then deploy the build artifacts generated from make html and make latexpdf (in the case of Sphinx).
I know services such as ReadTheDocs are available, however, in this use case I need the documentation generated by Sphinx or MkDocs to remain private.
Can anyone offer any guidance as to accomplish any of the following:
Here's the Bitbucket Pipelines file I quickly mashed up, however, I just found a few Docker images for Sphinx that will likely be a much better option to cut down on pipelines processing time (as this build took over 1 hour since Latexpdf is so large).
bitbucket-pipelines.yml
# You can use a Docker image from Docker Hub or your own container # registry for your build environment. image: python:2.7 pipelines: default: - step: script: # Modify the commands below to build your repository. - apt-get -qq update - apt-get install -y texlive-full - pip install -r requirements.txt - make html - make latexpdf
Thanks!
I just wrote up this guide on setting up ssh public-key authentication for use inside Pipelines. It seems like it might help with your preferred option.
The build succeeds and I know the artifacts are inside the container at:
Build finished. The HTML pages are in build/
html.
pdflatex finished; the PDF files are in build/latex.
