Builds section is blank. How to see build results under builds section
Serif Ciftcioglu
July 20, 2020
Build results are showing under commits section of repositories under builds column . I would also like to see builds, under builds section of repository.
Kristy
August 2, 2020
Hi @Serif Ciftcioglu ,
Can you please share what version of Bitbucket Server you are using? Also, what CI tool are you using?
If you are able, some screenshots showing the problem and describing where you would like to see the builds would also be helpful.
Kristy
Developer on Bitbucket Server
