×I have bitbucket server setup and working on my server. When I try to connect My server is getting the request but is not sending a response back to me.
Gitbash gives me a failed - time out.
sourcetree - a connection attept failed because the connected party did not properly respond
I am not sure where to go from here
Hi @[deleted] ,
Can you please expand a bit on your problem?
For proper support you can open a support ticket here: http://getsupport.atlassian.com
Hope that helps,
Kristy
