We run Stash which is connnected to the company active directory. We have noticed with two users now that suddenly their PCs are unable to interact with stash at all (can't pull, push, clone). We do not use putty or any ssh keys. However both users do have putty installed. I have eliminated certain things:
These two things suggest that there is nothing wrong with the user profile on stash (permissions etc are fine)
What I have summised from this is that the user has something in their profile (windows profile) that is causing the problem. We deleted one of these users entire profile and reconstituted it and this resolved the issue. This is obviously not an ideal solution.
My question is what do I need to delete from the users profile to make sure that they can authenticate with stash properly. A normal user gets prompted for their password when interacting with stash but these users do not get this request.
I have searched for an answer for ages but can't seem to find someone with a similar problem.
Any help would be appreciated.
Haemish
Version 1.9.5.msysgit.1 is broken, it doesn't send Realm in the authorization header. Use 1.9.5.msysgit.0.
The timeout error is coming from the Cisco Web Security Appliance. Do these users sit on a difference network or connect through a proxy to get to the server? If they have a local VPN running, have them turn it off and try again.
Thanks for your feedback. I have captured the logs below. The broken computer is first. It seems to find the server but then timesout because of a lack of response. Any thoughts. Thanks for your help so far. *********************************************The broken computer's log is********************************************* $ git pull * Couldn't find host ezstash.opmain.ds.corp in the _netrc file; using defaults * Trying 10.93.250.10... * Connected to zapryproxy01.opmain.ds.corp (10.93.250.10) port 3128 (#0) * Proxy auth using Basic with user 'ezwest' > GET http://ezhaem@ezstash.opmain.ds.corp/scm/latex/doctemplate.git/info/refs?s ervice=git-upload-pack HTTP/1.1 Proxy-Authorization: Basic ZXp3ZXN0OkhvcGUyMDE1 User-Agent: git/1.9.5.msysgit.1 Host: ezstash.opmain.ds.corp Accept: */* Accept-Encoding: gzip Proxy-Connection: Keep-Alive Pragma: no-cache < HTTP/1.1 504 Gateway Timeout < Mime-Version: 1.0 < Date: Tue, 23 Jun 2015 14:15:51 GMT < Via: 1.1 ZAPRYPROXY01.opmain.ds.corp:3128 (Cisco-WSA/8.5.2-027) < Content-Type: text/html < Connection: keep-alive < Proxy-Connection: keep-alive < Content-Length: 2715 < * Connection #0 to host zapryproxy01.opmain.ds.corp left intact fatal: unable to access 'http://ezhaem@ezstash.opmain.ds.corp/scm/latex/doctempl ate.git/': The requested URL returned error: 504 ************************************************The working computer's log is***************************************** $ git pull * Couldn't find host ezstash.opmain.ds.corp in the _netrc file; using defaults * Adding handle: conn: 0x227efd0 * Adding handle: send: 0 * Adding handle: recv: 0 * Curl_addHandleToPipeline: length: 1 * - Conn 0 (0x227efd0) send_pipe: 1, recv_pipe: 0 * About to connect() to ezstash.opmain.ds.corp port 80 (#0) * Trying 10.93.228.21... * Connected to ezstash.opmain.ds.corp (10.93.228.21) port 80 (#0) > GET /scm/latex/doctemplate.git/info/refs?service=git-upload-pack HTTP/1.1 User-Agent: git/1.9.5.msysgit.0 Host: ezstash.opmain.ds.corp Accept: */* Accept-Encoding: gzip Pragma: no-cache < HTTP/1.1 401 Unauthorized * Server Apache-Coyote/1.1 is not blacklisted < Server: Apache-Coyote/1.1 < X-AREQUESTID: @1OE7SHYx978x72322x0 < X-ASEN: SEN-3068575 < X-XSS-Protection: 1; mode=block < X-Frame-Options: SAMEORIGIN < X-Content-Type-Options: nosniff < WWW-Authenticate: Basic realm="Atlassian Stash" < Content-Length: 0 < Date: Tue, 23 Jun 2015 14:18:58 GMT < * Connection #0 to host ezstash.opmain.ds.corp left intact * Issue another request to this URL: 'http://EZWEST@ezstash.opmain.ds.corp/scm/l atex/doctemplate.git/info/refs?service=git-upload-pack' * Couldn't find host ezstash.opmain.ds.corp in the _netrc file; using defaults * Found bundle for host ezstash.opmain.ds.corp: 0x2261b88 * Re-using existing connection! (#0) with host ezstash.opmain.ds.corp * Connected to ezstash.opmain.ds.corp (10.93.228.21) port 80 (#0) * Adding handle: conn: 0x227efd0 * Adding handle: send: 0 * Adding handle: recv: 0 * Curl_addHandleToPipeline: length: 1 * - Conn 0 (0x227efd0) send_pipe: 1, recv_pipe: 0 * Server auth using Basic with user 'EZWEST' > GET /scm/latex/doctemplate.git/info/refs?service=git-upload-pack HTTP/1.1 Authorization: Basic RVpXRVNUOg== User-Agent: git/1.9.5.msysgit.0 Host: ezstash.opmain.ds.corp Accept: */* Accept-Encoding: gzip Pragma: no-cache < HTTP/1.1 401 Unauthorized * Server Apache-Coyote/1.1 is not blacklisted < Server: Apache-Coyote/1.1 < X-AREQUESTID: @1OE7SHYx978x72323x0 < X-ASEN: SEN-3068575 < Set-Cookie: _atl_stash_remember_me=""; Expires=Thu, 01-Jan-1970 00:00:10 GMT; Path=/ * Authentication problem. Ignoring this. < WWW-Authenticate: Basic realm="Atlassian Stash" < Content-Length: 0 < Date: Tue, 23 Jun 2015 14:18:58 GMT < * Connection #0 to host ezstash.opmain.ds.corp left intact Password for 'http://EZWEST@ezstash.opmain.ds.corp';: * Couldn't find host ezstash.opmain.ds.corp in the _netrc file; using defaults * Found bundle for host ezstash.opmain.ds.corp: 0x2261b88 * Re-using existing connection! (#0) with host ezstash.opmain.ds.corp * Connected to ezstash.opmain.ds.corp (10.93.228.21) port 80 (#0) * Adding handle: conn: 0x227efd0 * Adding handle: send: 0 * Adding handle: recv: 0 * Curl_addHandleToPipeline: length: 1 * - Conn 0 (0x227efd0) send_pipe: 1, recv_pipe: 0 * Server auth using Basic with user 'EZWEST' > GET /scm/latex/doctemplate.git/info/refs?service=git-upload-pack HTTP/1.1 Authorization: Basic RVpXRVNUOkNhc3MyMDIz User-Agent: git/1.9.5.msysgit.0 Host: ezstash.opmain.ds.corp Accept: */* Accept-Encoding: gzip Pragma: no-cache < HTTP/1.1 401 Unauthorized * Server Apache-Coyote/1.1 is not blacklisted < Server: Apache-Coyote/1.1 < X-AREQUESTID: @1OE7SHYx979x72324x0 < X-ASEN: SEN-3068575 < Set-Cookie: _atl_stash_remember_me=""; Expires=Thu, 01-Jan-1970 00:00:10 GMT; Path=/ * Authentication problem. Ignoring this. < WWW-Authenticate: Basic realm="Atlassian Stash" < Content-Length: 0 < Date: Tue, 23 Jun 2015 14:19:06 GMT < * Connection #0 to host ezstash.opmain.ds.corp left intact fatal: Authentication failed for 'http://EZWEST@ezstash.opmain.ds.corp/scm/latex /doctemplate.git/'
I don't have much, but I would advise setting: set GIT_CURL_VERBOSE=1 then running the git command. You can post the output up here. Also compare it the output from one of the working users/machines.
That is correct yes. Under normal conditions we clone using a url like so: http://EZHAEM@ezstash.opmain.ds.corp/scm/latex/doctemplate.git it then requests a password (which is our windows active directory password) and once we put it in we are away. With the users experiencing this problem the password is never asked for!
You do not use SSH keys, so that implies all push/pull etc is over https?
