The above error comes up when trying to run sonarcloud pipeline. It does not even start executing the pipeline.
It looks like the docker image you're using doesn't have a shell in the standard location "/bin/sh". If you have a local docker installation you can test this with a command like:
docker run -it my/image:tag /bin/sh
If that fails then you won't be able to use that image in Pipelines. You could try finding or building another docker image that has a shell installed at "/bin/sh".
