Hello, I have a problem with Bitbucket 5.7
anatolistoev
February 14, 2018
Hello, I have a problem with Bitbucket 5.7 I can not locate bitbucket.properties or server.xml I want to setup ssl but do not find config file.
10x
Anatoli
Christian Glockner
February 14, 2018
Hi Anatoli,
By the default the bitbucket.properties file doesn't exist, so you will have to create it in <BitbucketHome>/shared. The server.xml file is no longer relevant in version 5, so it doesn't exist anymore.
Christian
Premier Support Engineer
Atlassian
