Help needed in using helm deployments in bitbucket pipelines
Vinay Muralimohan
I am using bitbucket pipelines to build my gradle project , dockerize the app, upload the docker image using AWS ECR pipe and finally deploy the docker image into AWS EKS using pipe. Now I want to utilize helm chart to deploy my app into EKS cluster and I couldn't find any support or example or any plugin/pipe to achieve the same.
Can anybody help me how to achieve the same?
Vinay
Yves Vogl October 31, 2023
I created a pipe for this some years ago. I tried to contribute it to Atlassian but they did not accept contributions from individuals.
https://github.com/yves-vogl/aws-eks-helm-deploy
Rajneesh Mitharwal
October 6, 2020
Vinay Muralimohan
Have gone through this before posting, that solution doesn't cut it for me. Anyway I created a shell script to get executed with list of aws cli, kubectl and helm install commands to complete the deployment.
Nicola Abis
November 16, 2020
Hi Vinay, I want to use helm in pipeline too (although my need is only to run `helm template` command). Could you please share your shell script and/or bitbucket-pipelines.yml file with the helm commands to deploy on k8s cluster?
That would be very nice of you and very helpful for me :)
Like • Sabine Mayer likes this
