Help with pipeline cache clearing
helberlucio
April 8, 2022
Even creating a new user and having all the permissions and writing is giving an authentication error when I run the pipeline in the cash cleaning part;
o_kyrdan April 8, 2022
Hi @helberlucio
Have you tried to use bitbucket-clear-cache pipe ?
Note! According to the Readme documentation:
This pipe requires Bitbucket credentials (username and app password) so that the pipe can communicate with Bitbucket APIs to retrieve and clear dependency caches. When generating the app password, remember to check the Pipelines Write and Repositories Read permissions.
Hope, this could solve your problem.
Best regards,
Oleksandr Kyrdan
