How to create project in bit bucket using bit bucket REST API?
Vaasanthi January 12, 2018 edited
We are trying to create projects in bit bucket automatically.
Tried the following  options and it didn't work. can some one guide?
1. curl -k -X POST --user UID:PWD "https://bitbucket.example.com/context/rest/api/1.0/projects" -d "name=vptest"
2. curl -X POST -v -u UID:PWD "https://bitbucket.example.com/projects" -H "Content-Type: application/json" -d '{"scm": "git", "is_private": "true", "fork_policy": "no_public_forks"}'
3. curl-k -X POST --user "UID:PWD" https://bitbucket.example.com/rest/api/1.0/projects?name='test_project'
Edwin Kyalangalilwa
January 13, 2018
Hi Vaasanthi,
You can use this python api.
https://pypi.python.org/pypi/stashy/0.3
pip install stashy
import stashy
bitbucket = stashy.connect(host, user, pass)
bitbucket.projects.create("TEST", "Test")
Prakash Ganeshan June 18, 2019
I am able to create a project in Bibucket server using this API:
curl -D- -u username:Password -d "{ \"key\": \"PRA\", \"name\": \"My project\", \"description\": \"My First project through API\" }" -H "C
ontent-Type: application/json" http://servername:7990/rest/api/1.0/projects
Vvp Vp
March 17, 2021
I have a similar request
curl -D- -u username:Password -d "{ \"key\": \"PRA\", \"name\": \"My project VVP\", \"description\": \"My First project through API\" }" -H "Content-Type: application/json" https://bitbucketexample.com/rest/api/1.0/projects
*https://bitbucketexample.com replaced with my URL.
but i got an error
{"errors":[{"context":null,"message":"You are not permitted to access this resource","exceptionName":"com.atlassian.bitbucket.AuthorisationException"}]
I am a admin, so what is missing here.
Rashmi May 1, 2019
Hi Vasanthi,
Were you able to create project using API?
atlassian, jira, marketing project management, jira for marketers, agile marketing, campaign planning, marketing workflows, jira templates, atlassian learning, marketing collaboration, project tracking, marketing teams, jira training
Streamline Marketing in Jira 🖼️
Plan, prioritize, and deliver marketing projects seamlessly. See how Jira supports your team's success. Start today!
Start now! 🚦
