How to deploy several sub modules in a same repository using bit bucket pipeline?
saniddha
January 9, 2018
I have three micro service modules and i want to deploy them in aws using bit-bucket pipeline
lassian
January 30, 2018
HI Saniddha
The following documentation page has instructions on how to setup pipelines to deploy to various different AWS services
Deploy to AWS from Bitbucket Pipelines
If you have multiple modules in your repository you you will need to setup your yml to either:
  • Use one step to deploy all 3 at once using the required bash commands as described on the page above or the same ones you for AWS from your laptop
  • Use multiple serial steps with each step deploying a different module using the required bash commands as described on the page above or the same ones you for AWS from your laptop
There are also a few different answers on the community about how to deploy to various AWS services such as this one about deploying to AWS Lambda
Deploying to AWS Lambda from Bitbucket Pipelines
Regards
