How to fix continuous build failed pipelines
Jaehyeong Hwang
August 3, 2023
I kept failed build pipelines and I screwed up by trying to fix it by myself, I reverted lots of commits, and also deleted branches.
Now, The last commit that was merged with master is not even building.
The build failed sentence says
Failed
Currently no online runner available that matches the required labels.
and there is nothing on build screen. It says "No logs to display"
Can anyone help me how to make the build success again ?
Br,
Jaehyeong Hwang
Mark C
August 8, 2023
Hi @Jaehyeong Hwang,
Welcome to the community.
Based on the error message "Currently no online runner available that matches the required labels.", it seems you either don't have a runner running on your self-hosted machine or you're using a different label for your YAML step configuration.
          runs-on:
            - 'self.hosted'
            - 'my.custom.label'
I'd suggest trying to check your self-hosted machine if there's a runner running and check your current YAML configuration to see if you're using the correct labels.
Alternatively, you can also try to create a new runner.
Mark C
Jaehyeong Hwang
August 9, 2023
Thank you for the answer.
But I asked the question in detail on support channel, and got the solution. Had to create a new runner for workspace and followed the instruction, after that I just reloaded the yaml file by committing nothing(just added space). Then it went ok.
Br,
Jaehyeong Hwang
