How to get OAUTH Consumer Key and OAUTH consumer Secret for STASH(BitBucket)
Sangitown
April 18, 2016
I am working on the web hook triggers for Container Hub that is getting deployed.  We are using an app called Quay by CoreOS.  They have a Bit-Bucket server plug in on there side and asking for below items:
  1. OAUTH Consumer Key
  2. OAUTH consumer
Please help.
dhrupeshk
January 16, 2019
how can i find consumer key in jIra ? I  have login with free trail but didn't find anywhere?
Dario B
January 31, 2019
This is a totally different question that I believe you should ask in a new thread.
However, if this is for jira cloud you can check below documentation:
https://developer.atlassian.com/cloud/jira/platform/jira-rest-api-oauth-authentication/
Deleted user September 20, 2017
The question is about "Stash" which, as we all know, is now called "Bitbucket Server". All the links you list have either been deleted or are Bitbucket Cloud documentation.
I would appreciate it if someone could answer the question about Bitbucket Server: how do you set up the consumer and get the key?
