Say I have 200 repos for which I can set-up appropriate pipelines. Is it possible to get a unified Activity Feed of deployment activity across all of my repos? I've seen the following questions/issues which seem related, but don't directly address the above:
For now, the best workaround seems as though to configure a sidecar Slack (or possibly Teams) channel and to have all pipeline / deployment messaging sent there.
Hey David,
Thanks for reaching out! We currently don't support project-level / multi-repo dashboards for pipeline or deployment activity, but we have a few open feature requests to support this that you might want to vote for / follow:
* https://bitbucket.org/site/master/issues/16400/dashboard-for-viewing-deployment-statuses
* https://bitbucket.org/site/master/issues/12765/pipeline-wallboards
* https://bitbucket.org/site/master/issues/13293/global-pipelines-activity-log
As for being able to configure Pipelines for multiple repos, you can use pipes for this. Pipes are a way to encapsulate scripts which can then be called from different repositories. For more information on how to write your own pipe, check out our guide.
Aneita
