pipelines:
default:
- step:
image: node
script:
- npm install
- npm run seed
- npm test
services:
- postgres
definitions:
services:
postgres:
image: postgres
environment:
POSTGRES_DB: postgres
POSTGRES_USER: postgres
POSTGRES_PASSWORD: postgres
You can try adding the command "npm start &" to your bitbucket-pipelines.yml file after the "npm install" command. This will run the "npm start" command in the background, allowing the "npm run seed" and "npm test" commands to run afterwards.
