×I've generated a new project using atlas-create-bitbucket-plugin. Everything runs fine, except for integration tests.
[ERROR] Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 6.019 s <<< FAILURE! - in it.test.MyComponentWiredTest
[ERROR] initialization(it.test.MyComponentWiredTest) Time elapsed: 6.018 s <<< ERROR!
java.lang.Throwable: unable to find runner for class: it.test.MyComponentWiredTest
[INFO]
[INFO] Results:
[INFO]
[ERROR] Errors:
[ERROR] MyComponentWiredTest.initialization » Throwable unable to find runner for clas...
[INFO]
[INFO]
What should I be looking for?
Hi Liri, thanks for your question!
However, for questions like this one where you're developing your own plugin, it's best if you direct it to our Developer Community.
The users there share a programming background and they'll be better equipped to help you with your question.
Best regards,
Ana
