×The thing is with GIT Repo, once you hit 2GB limit it won't let you push anything. That means for my case, even though I already deleted large unnecessary files on my local branch history using git filter method, it still requires me to push forcibly the changes which the repo will not allow you anymore because of the said limit reached.
On the other hand, I also did git remote prune method which did not help because it seems I do not have dangling objects on my remote side which is very unlikely knowing the 2GB limit has been reached.
Note: I've also done git reset --hard method in the beginning which probably lost that commit that was reset that has big files.
Hi JonCarlo,
It is really good that you have tried all the steps at first hand.
git remote prune will only remove the remote tracking references to remote objects from local repo. git gc is currently run by Atlassian Support team which will remove any dangling commits.
You can raise a support request with Atlassian Support selecting Technical Issues and Bugs option to run a gc on your repository to bring down the repository size. After which you can push your local changes. Please don't forget to mention your repository URL in the support ticket.
Best Regards,
Swetha
