Problem brief
I develop a simple plugin for our self-hosted Bitbucket Server. In this plugin I have a web-panel, which appeared on each Pull Request in bitbucket.web.repository.banner.
On dev-localhost environment by Atlassian all my changes works and shows correctly. But after packaging my plugin to jar and sending to our admins for installation, something strange happens: the plugin is successfully installed, merge-checks work correctly, logs from the java-code successfully come, but I don't see my web-panel (but on dev-env I always can see it).
Context
atlassian-plugin.xml
<atlassian-plugin key="${atlassian.plugin.key}" name="${project.name}" plugins-version="2">
<web-panel key="specific-key-for-web-panel" location="bitbucket.web.repository.banner">
<resource name="view" type="velocity" location="/html/file-name.html"/>
<condition class="path.ConditionFileName" />
</web-panel>
</atlassian-plugin>
Questions
What could be the problem?
How can I catch the problem if I do not have direct access to the server? (I have access to atlassian-bitbucket.log file only)
UPD 1 (few plugins on the server)
UPD 2 (for the first time, everything was fine)
Hey @bukshev what web-resource context do you use to load the JS/CSS assets?
With Bitbucket 7.0 we introduced a new context name on the pull request page:
bitbucket.page.pullRequest.detail
https://developer.atlassian.com/server/bitbucket/reference/web-resource-contexts/
Let me know if that helps.
Maciej
