Need Qt for build my project. How to get?
dismine
For successful build my project i need Qt library installed in system. I tried run with default image and still get error "bash: qmake: command not found". How to install Qt?
4 votes
dismine
Ok, i have found answer myself. These two command installed Qt for me.
- apt-get update
- apt-get install -y qtbase5-dev libqt5svg5-dev qt5-default
qttools5-dev-tools libqt5xmlpatterns5-dev libqt5core5a libqt5gui5
libqt5printsupport5 libqt5svg5 libqt5widgets5 libqt5xml5
libqt5xmlpatterns5
sam October 10, 2016
Roman, how do I get started building Qt apps with bb pipelines?
Roman
October 11, 2016
simon, did you read the tutorial? It is really straightforward. What exactly you did not understand?
sam October 12, 2016
The tutorial says, you can use a docker image from docker hub, but I don't know how to do that exactly. So, what does (the start of) your pipelines.yml look like? Do you need to put the script from your .pro file in it?
Roman
October 12, 2016
