Need help with function to get source branch of pull request
Shobhit Gupta January 23, 2021
Can someone help to know which function can give source branch name when pull request is created.
jmarquesadaptavist May 5, 2021
Hi @Shobhit Gupta
In order to get the source branch name when the pull request is created you can create a Custom Listener for PullRequestOpenedEvent event and then you can use pullRequest.fromRef.displayId in your script.
Many Thanks and Kind Regards,
Jose Marques
Software Engineer - ScriptRunner for Bitbucket
