Need help with git svn clone
SamuelHenderson October 23, 2014
Hi everyone...  I've got an SVN Repository that has many different unrelated projects in the trunk and I'm trying to clone each project into it's own bitbucket/git repository.  I followed the migration guide from Atlassian (https://www.atlassian.com/git/tutorials/migrating-overview) but I seem to be running into some trouble.
I downloaded and installed all the required tools in Ubuntu and then downloaded the svn migration script.  I was able to build the authors.txt file no problem but when I tried to run the next step (Convert) nothing seems to happen.
Here is what I am running:
~$ git svn clone --stdlayout --authors-file=authors.txt "https://core-wsus.cgc.local:8443/svn/NEW/trunk/CGC/AssessmentUploader SqlServer" assessment-uploader
 And here is the output:
Initialized empty Git repository in /home/ssmic/GitMigration/assessment-uploader/.git/
Using higher level of URL: https://core-wsus.cgc.local:8443/svn/NEW/trunk/CGC/AssessmentUploader SqlServer => https://core-wsus.cgc.local:8443/svn/NEW
W: Ignoring error from SVN, path probably does not exist: (160013): Filesystem has no item: File not found: revision 100, path '/trunk/CGC/AssessmentUploader SqlServer'
W: Do not be alarmed at the above message git-svn is just searching aggressively for old history.
This may take a while on large repositories
However when I view the output directory it is empty aside from a .git folder.  What am I missing here?
John Garcia
October 23, 2014
Samuel, it's normal for git to use a <repository>/.git folder to hold the entire repository, and then use the parent of that as the working tree. If the method does not check out a working tree, you'll end up with an empty folder containing only the .git folder, in which case you should be able to git checkout a working tree.
Hmmm Ok.  I tried that.  Here's what I got:
ssmic@bitbucket:~/GitMigration/assessment-uploader$ cd ..
ssmic@bitbucket:~/GitMigration$ git clone assessment-uploader assessment-uploader2
Cloning into 'assessment-uploader2'...
done.
warning: You appear to have cloned an empty repository.
I can confirm that the new directory is also empty.
One thing I just thought of: when I initially did the git svn clone step I saw a message that disappeared saying "Checked through to r900" however our SVN Repository has over 3300 revisions
John Garcia
October 23, 2014
Hmm, in that case go back to the repository's container:
cd..
git clone &lt;repo&gt; &lt;newname&gt;
cd &lt;newname&gt;
Your new clone of the repo should have all of the data of the master copy, plus a working tree.
So I need to cd into the newly created project folder (in this case assessment-uploader) and then run
$git checkout
I did that... but there's still no source?
Hector Ojeda March 1, 2016
Hi @Samuel Henderson, Did you manage to solve this?
