No single ai review generated for weeks
Thomas Kekeisen
We enabled the new code reviewer a few weeks ago but since then not a single comment was created. Is there any common issue we could have made? Anything more required than just "enabling" the feature?
Mark C
June 20, 2025
Hi @Thomas Kekeisen
Thank you for reaching out to the community.
Could you confirm if Rovo Dev Agents is activated in your workspace and the specific repository?
Mark C
Thomas Kekeisen
Mark C
June 25, 2025
Hi @Thomas Kekeisen
Thanks for the confirmation.
Could you check if the repository and PRs inside it is not hitting the limitations mentioned here? - https://rovodevagents-beta.atlassian.net/wiki/external/MmVjYmFiNzA1NjQ0NGZjODg5NTBhMGM3OTQyYTQ4MmY#Code-Reviewer-specifications
Mark C
Thomas Kekeisen
Hi Mark,
thank you. I can also confirm that none of the limitations are hit. Do you have any logs on your side?
Thomas
Product Admin Site Admin
