×Hi, since about two hours we are experiencing issues when trying to start an Azure DevOps Build pipeline with it's repo in Bitbucket.
We are getting the following error:
The pipeline is not valid. Could not get the latest source version for repository xxxxxx/xxxxxxx hosted on Bitbucket using ref refs/heads/slowlane. Bitbucket reported the error, "Request timed out after 30000 ms"
Dos anyone has any idea how to get this solved?
Hi @Mels de Zeeuw @Rafael Mota
Thank you for your report. Our team has fixed the problem. All affected products are now back online and no further impact has been observed. We know that you rely on our products for your daily operations and productivity, and we sincerely apologize for any impact this disruption has had on your teams. We will conduct and publish a post-incident review (PIR) with more details about the incident and the steps we are taking designed to prevent similar occurrences in the future. We plan to post the PIR on our Statuspage within 30 days.
We sincerely apologize for this inconvenience and appreciate your patience.
- Ben (Bitbucket Cloud Support)
Hi Mels,
Bitbucket Cloud is experiencing degraded performance and several components are affected. Our apologies for the inconvenience caused by this.
You can subscribe for updates in the following incident on status page:
Our engineering team is working to restore the services.
Theodora
the servers are down, check:
https://bitbucket.status.atlassian.com/
I was already checking the status page several times. But till I created this topic all statuses were ok/green.
But luckily it solved now.
