OIDC not working with aws-cli but works with pipes
Deb Mohan June 1, 2022
I am trying to use OIDC with a role and a web identity on aws. I followed the steps from https://support.atlassian.com/bitbucket-cloud/docs/deploy-on-aws-using-bitbucket-pipelines-openid-connect/
As noted at the end of the post, the OIDC works when I use atlassian pipes but it does not work with the export and aws cli options.
# bitbucket pipeline - this one fails
image: amazon/aws-cli
pipelines:
default:
- step:
name: Connect to AWS using OIDC
oidc: true
script:
- unset AWS_SECRET_ACCESS_KEY
- unset AWS_ACCESS_KEY_ID
- export AWS_REGION=$AWS_REGION
- export AWS_ROLE_ARN=arn:aws:iam::1234567890:role/MyRole
- export AWS_WEB_IDENTITY_TOKEN_FILE=$(pwd)/web-identity-token
- echo $BITBUCKET_STEP_OIDC_TOKEN > $(pwd)/web-identity-token
- printenv BITBUCKET_STEP_OIDC_TOKEN
- printenv AWS_REGION
- printenv AWS_ROLE_ARN
- aws sts assume-role-with-web-identity --role-arn arn:aws:iam::1234567890:role/MyRole --role-session-name build-session --web-identity-token "$BITBUCKET_STEP_OIDC_TOKEN" --duration-seconds 1000
- aws sts get-caller-identity
# Output from the above:
printenv AWS_REGION
us-east-2
<nothing here>
# Error:
An error occurred (AccessDenied) when calling the AssumeRoleWithWebIdentity operation: Not authorized to perform sts:AssumeRoleWithWebIdentity
# this one works with the same AccessIdentityRole to copy files from my build to the s3 bucket
- pipe: atlassian/aws-s3-deploy:1.1.0
variables:
AWS_DEFAULT_REGION: $AWS_REGION # Optional if already defined in the context or OIDC used.
AWS_OIDC_ROLE_ARN: $AWS_OIDC_ROLE_ARN # Optional by default. Required for OpenID Connect (OIDC) authentication.
S3_BUCKET: mygreat-bucket
LOCAL_PATH: 'build'
CACHE_CONTROL: 'max-age=86400'
# Role Policy:
"Version": "2012-10-17",
"Statement": [
"Effect": "Allow",
"Action": "*",
"Resource": "*"
# Trust Relationship:
"Statement": [
"Effect": "Allow",
"Principal": {
"Federated": "arn:aws:iam::1234567890:oidc-provider/api.bitbucket.org/2.0/workspaces/myworkspace/pipelines-config/identity/oidc"
"Action": "sts:AssumeRoleWithWebIdentity",
"Condition": {
"StringEquals": {
"api.bitbucket.org/2.0/workspaces/myworkspace/pipelines-config/identity/oidc:sub": "w234y098-f0tk-823a-45m1-qwrth8912n00:*"
Patrik S
June 6, 2022
Hello @Deb Mohan ,
Thank you for reaching out to Atlassian Support.
From the error message, you are receiving it seems the policy/trust relationship you are currently using is not allowing the pipeline's environment to assume the role :
Accordingly to the trust relationship you have shared, it seems you have configured it to allow only the repository with the UUID below to assume the role :
Checking for that UUID internally I was not able to find it associated with any repository. Could you please double-check if the value is correct? You can do that by following the below steps :
If that does not work, you can also try to remove the trust relationship condition temporarily and test running your build again to check if the command you are executing is able to assume the role.
Hope that helps, let me know in case you have any questions!
Thank you, @Deb Mohan .
Patrik S
Deb Mohan June 6, 2022
@Patrik S
I am using a repository ID. for the purpose of security I did not share the repository id here as it is a public domain.
If you provide me with an email I can share my repo ID.
I have already tested the the trust with the braces and it did not work. Currently the only way the OIDC is working is with the audience.
Patrik S
June 6, 2022
Hello @Deb Mohan ,
As I suspect the issue is the string not matching your trust relationship, could you try removing the "String equals" section of your trust relationship, leaving the "Conditions" object empty, and try again?
You can also print the value of the variable inside your build
so you will get the token bitbucket will use to assume the role in AWS. You can then debug that token in jwt.io and see if the "sub" field of the JSON matches the Repository UUID value you have configured in the trust relationship. The sub claim is formed like the following :
{REPOSITORY_UUID}[:{ENVIRONMENT_UUID}]:{STEP_UUID}
E.g.
{1de489be-ce6a-42a0-a8c8-eadbf1174ac7}:{bd715740-c970-486b-b68a-b421ec2a1f8b}:{759de0c6-eaee-4eaa-b7a6-c507eec759a7}
{1de489be-ce6a-42a0-a8c8-eadbf1174ac7}:{759de0c6-eaee-4eaa-b7a6-c507eec759a7}
ENVIRONMENT_UUID: This part shows up only if the step is assigned to a deployment environment.
Patrik S
Hi @Patrik S ,
I have been using Trust Relationship with Audience and it works and it did without any conditions too. The problem is with the sub option. Looks like something is wrong with the way the policy is created or the string is passed. I checked the cloudtrail logs and do not see anything wrong. I am not sure what the problem would be.
As I mentioned earlier for some reason
does not work. I get nothing in the response.
Patrik S
June 7, 2022
Hello @Deb Mohan ,
You are not able to see the value of the OIDC Token because the $BITBUCKET_STEP_OIDC_TOKEN is considered a secure variable, so its value is masked from the logs for security reasons.
In order to check the value of that variable you can output it to a file, and make that file available as an artifact, as the below example :
- step:
oidc: true
script:
- echo $BITBUCKET_STEP_OIDC_TOKEN > my_token.txt
artifacts:
- my_token.txt
After the build finishes, the file should be available in the artifacts tab of that build, so you can download and verify the value of the token, and inspect it in jwt.io to check for the "sub" value.
Patrik S
Deb Mohan June 10, 2022
@Patrik S
Thank you for the tip. I verified the sub and I have it correct in my Trust Relationship policy. Still does not work.
Patrik S
June 10, 2022
Hello @Deb Mohan ,
In this case, I would suggest trying to enable the Cloud Trail logs on AWS for IAM and STS services, so you can potentially get more information on why AWS is denying your pipeline to assume the role when using the sub filter.
I found the following aws documentation on how to enable the logs for the calls to IAM and STS APIs that might be of help :
Patrik S
Like Steffen Opel _Utoolity_ likes this
blake.dobay
August 24, 2022
Can confirm, this is definitely an issue. Audience works fine but sub is not functioning. Have confirmed via the extracted token that the repo UUID is correct compared to my AWS policy.
Inspection of  Cloudtrail only gives: "errorCode": "AccessDenied",
"errorMessage": "An unknown error occurred"
Patrik S
September 1, 2022
Hello @blake.dobay ,
Welcome to Atlassian Community
Could you try setting up the Trust Relationship in AWS using the condition StringLike , instead of StringEquals, like the below example :
  "Effect": "Allow",
  "Principal": {
    "Federated": "arn:aws:iam::{AWS_ACCOUNT_NUMBER}:oidc-provider/api.bitbucket.org/2.0/workspaces/{WORKSPACE}/pipelines-config/identity/oidc"
  "Condition": {
    "StringLike": {
      "api.bitbucket.org/2.0/workspaces/{WORKSPACE}/pipelines-config/identity/oidc:sub": "{REPO_UUID}:*"
Reference: https://support.atlassian.com/bitbucket-cloud/docs/deploy-on-aws-using-bitbucket-pipelines-openid-connect/#Allowing-only-a-specific-repository-to-assume-the-role
Thank you,
Patrik S
Jack Williams
August 20, 2024
StringLike was the fix for me.
Like Patrik S likes this
Tried with no condition and it works as expected. I have been using the audience and it works too. Just that when I want to use the repositoryUuid with the sub, the build breaks. I guess there is a problem with the sub.
Also as suggested, I am not getting any response for the echo statement.
