Pipe for azure webapp deployments using container registry image
Andrea Calderon March 7, 2024
We want to deploy a WebApp from pipelines using a image from Azure Container Registry, or If is possible deploy a container, but I'm not able to find a pipe for that.
What should be recommended for WebApp deployments with Azure Container Registry?
Thanks for the help.
Igor Stoyanov
March 8, 2024
Hi @Andrea Calderon . There is a Bitbucket pipe to push to Azure Container Registry.
- pipe: atlassian/azure-acr-push-image:0.3.0
  variables:
    AZURE_TOKEN_NAME: "<string>"
    AZURE_TOKEN_PWD: "<string>"
    AZURE_REGISTRY: "<string>"
    IMAGE_NAME: "<string>"
    TAGS: "<string>" # Optional
    # DEBUG: "<boolean>" # Optional
More pipes for Azure you could discover at the Bitbucket Pipes Marketplace.
Regards, Igor
