Pipe "rsync-deploy" does not work with `--rsync-path`
Marvin Heilemann January 25, 2024
I am unable to use spaces in `--rsync-path`. Tried these variants:
- EXTRA_ARGS as Array: `- "--rsync-path=sudo -u www-data rsync"`
- `"--rsync-path=sudo -u www-data rsync"`
- `--rsync-path=sudo -u www-data rsync`
- `--rsync-path="sudo -u www-data rsync"`
- `--rsync-path='sudo -u www-data rsync'`
Igor Stoyanov
January 26, 2024
Also you could check this answer if example in my first message will not help:
https://community.atlassian.com/t5/Bitbucket-questions/EXTRA-ARGS-filter-bug/qaq-p/2107584
Igor Stoyanov
January 26, 2024
Hi @Marvin Heilemann . Here is example with an EXTRA_ARGS as an array when you have multiple args or whitespace characters to cover cases with escaping.
script:
  - pipe: atlassian/rsync-deploy:0.12.0
    variables:
      USER: 'ec2-user'
      SERVER: '127.0.0.1'
      REMOTE_PATH: '/var/www/build/'
      LOCAL_PATH: 'build'
      DEBUG: 'true'
      EXTRA_ARGS:
        - "--filter=P assets/css" # double quotes here are necessary
        - "--exclude=*.txt"
Are you sure you follow this example?
Provide us with the error details if you will still have this issue. Also you could see the generated rsync command in the logs.
Regards, Igor
elanclarkson May 29, 2024
This solution worked for me.
E.g.
EXTRA_ARGS:
- "-og"
- "--chown=apache:apache"
- "--chmod=D775,F664"
- "--rsync-path=sudo rsync"
Thanks @Igor Stoyanov!
Like Igor Stoyanov likes this
