Pipeline minutes between manual steps on
Daniel Mortensen
April 29, 2020
I am creating a bitbucket-pipelines.yml file that runs on both individual branch commits and in some cases on pull request creation. Some of these have multiple steps where one or more steps has a manual trigger.
 develop*:
- step:
script:
- echo "this is a step that runs automatically"
- step:
trigger: manual
script:
- echo "this is a step that runs manually"
After the first step completes the pipeline just sits there until I manually trigger step two. Can someone confirm whether or not this time between actual steps running incurs pipeline minutes? I assume not but I would like confirmation of this and haven't been able to find it in any of the documentation I read. Thanks!
(I'm not sure why the formatting of the code is like it is. Rest assured the yml I'm writing is correct and running as expected)
mkleint
July 22, 2020
minutes are only incured when a pipeline step is actually running. If you have parallel steps each gets counted separated, we only charge for the time your steps run in our kubernetes cluster.
