I have a problem when connecting to the atlassian repository: https://m2proxy.atlassian.com/repository/public. TortoiseSVN says that it is unable connencting at this URL. What should i do in order to connect to this repository?
Greetings,
John
It can depend on your setup environment and might be a problem with that URL. I hit it, I get a 404.
Thnx. for your answer. The problem with 404 is that there is a "." at the end of the link. I can see the contents of this repository, but can not reach it from SVN.
