Problem installing Stash 3.7 to use PostgreSQL
Mark Ruedy March 24, 2015
I am following the instructions on https://confluence.atlassian.com/display/STASH/Connecting+Stash+to+PostgreSQL
But after running the two "CREATE" commands in psql, the user still does not seem to be valid.  During install the test connection to the database fails and I also can't connect from the command line like this:
-bash-4.2$ psql -h localhost -d stash -U stashuser -W
Password for user stashuser:
psql: FATAL: Ident authentication failed for user "stashuser"
-bash-4.2$
My CREATE commands were
CREATE ROLE stashuser WITH LOGIN PASSWORD 'JELLYFISH' VALID UNTIL 'infinity';
CREATE DATABASE stash WITH ENCODING='UTF8' OWNER=stashuser CONNECTION LIMIT=-1;
I am new to PostgreSQL so could there be more I need to do there?  Like flush privileges or something?
This is a new server I am setting up, with hardware more like what we wish to deploy.
Mark
IT BS
May 5, 2015
What were your remved config lines ?
Mark Ruedy March 25, 2015
I found there where other config lines in pg_hba.conf causing the problem.  I've eliminated them, restarted postgresql.  Now it works fine.  Sorry about that.
I updated the pg_hba.conf to what you have (left off IPv6 part) but still get the same message.  Is that postgresql user supposed to match some OS user/pass or is it confined to postgresql?
[root@gitpc data]# psql -h 127.0.0.1 -d stash -U stashuser -W
[root@gitpc data]#
Is there any debugging facility for postgresql authentication?
rrudnicki
March 25, 2015
Hi Mark,
Try to use 127.0.0.1 instead of localhost. Look my example:
[root@lab mysql]# psql -h 127.0.0.1  -d confluence57 -U atlassian -W
Password for user atlassian:
psql (8.4.20, server 9.4.1)
WARNING: psql version 8.4, server version 9.4.
         Some psql features might not work.
Type "help" for help.
confluence57=> \q
[root@lab mysql]# psql -h localhost  -d confluence57 -U atlassian -W
psql: FATAL:  Ident authentication failed for user "atlassian"
[root@lab mysql]#
My pg_hba.conf is like this:
# "local" is for Unix domain socket connections only
local   all         all                               trust
# IPv4 local connections:
local all postgres trust
host    all         all         127.0.0.1/32          trust
host all     all  192.168.213.129/32  md5
# IPv6 local connections:
host    all         all         ::1/128               ident
host all     all  192.168.0.0/24  md5
Renato Rudnicki
Also, I already added the following lines to /var/lib/pgsql/data/pg_hba.conf, restarted postgresql but get the same message trying to open the database local all all trust host all all 127.0.0.1/32 trust
