I'm trying to build a JHipster project using Bitbucket pipelines. I configured yml conf file so that it uses a jhipster development docker image (JHipster Installation docs) which has everything that is needed for development of such project. Everything goes fine until maven-copy-resources plugin action.
I get the following error:
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-resources-plugin:3.0.0:copy-resources (default-resources) on project pplsreport: Cannot create resource output directory: /opt/atlassian/bitbucketci/agent/build/target/classes -> [Help 1]
Can someone please help?
This is bitbucket-pipelines.yml:
# You can use a Docker image from Docker Hub or your own container # registry for your build environment. image: jhipster/jhipster:v3.4.2 pipelines: default: - step: script: # Modify the commands below to build your repository. - ./mvnw --version - ./mvnw -Pprod clean install
Hi Misel,
I've looked into this, and it is a known issue at the moment. The Bitbucket Pipelines team is tracking the bug here:
https://bitbucket.org/site/master/issues/12956/i-cant-write-to-build-directory-when-user
You can 'watch' the issue to get notified when it is fixed.
Thanks for the info!
I hope it gets fixed soon.
This issue has been fixed now.
