Problem with private repo clone from Bitbucket Pipeline
Herman_Lintvelt April 18, 2018
Hi, we have a bitbucket repo (let's call it repo-1) that needs to clone another private repo (repo-2). Actually it needs to do this via a pip install, but we have also tested via normal `git clone`.
We have tried both the `Pipeline | SSH Keys` setting (on repo-1) and then giving that public key access via the `User Access Keys` setting on repo-2, as well as doing our own key and making that available as environment var to the bitbucket pipeline in repo-1.
In the case of trying a simple git clone, both these fail:
+ git clone git@bitbucket.org:our-org/private-repo-2.git
Cloning into 'custos-video-client'...
ssh_askpass: exec(/usr/bin/ssh-askpass): No such file or directory
Host key verification failed.
fatal: Could not read from remote repository.
It also looks like a password is expected for the private key, but afaik when using keys generated under `Pipeline | SSH Keys` setting, no passwords are involved?
Is there anything else we can look at, or perhaps some issues/constraints with accessing private bitbucket repos from a pipeline that we should be aware of?
davina
April 18, 2018
Hi Herman,
I am able to successfully clone a private repository (repo-current) into another private repository (repo-to-clone)
Steps I took:
  • Go to repo-current Settings -> Pipelines -> SSH Keys and Generate keys.
  • Copy public key to my Bitbucket account -> Settings -> SSH keys.
  • Add git clone repo-to-clone command to my bitbucket-pipelines.yml
  • Run pipeline - the image I used was atlassian/default-image:latest
The error you're seeing
looks environment specific. It could be related to the image you're using.
If issues persist, I would recommend debugging this locally as described here.
Hope this helps as a starting point!
Herman_Lintvelt April 19, 2018
Thanks, I was starting to think the same. We did base our docker image on the default atlassian one, but then also customized it, could be that something was done wrong there.
