Pull requests between two stash repositories inside a project?
Suresh Nelamangala February 21, 2013
Inside a project , we can have multiple repositories, however the pull request is only between branches.
Is there an option to have pull request between repositories.
jhinch (Atlassian)
February 21, 2013
Currently (Stash 2.1) this is not possible. There is an open feature request for adding support for repository forks. This would allow pull requests between forks.
https://jira.atlassian.com/browse/STASH-2495
Adding support for forks (and pull requests between them) is high on our priority list so hopefully you'll see the feature land really soon. Stay tuned!
sonicdivx
July 24, 2014
What is the status of this? Have pull requests between repos. been implemented. I don't see it in our companies implementation, but maybe it is a permissions thing.
TimP
July 24, 2014
Yep! Support for pull requests between forks shipped Stash 2.4.0. I'd check what version of Stash your company is running and consider upgrading.
Like _blsk likes this
sonicdivx
July 24, 2014
Tim,
I just opened our Stash server and it says 3.1.3. So maybe this is an admin setting. If so I'll ping admin to change. Not sure why something like this would be disabled unless they don't want devs all over "marking" their territory ;)
TimP
July 24, 2014
Hi Kevin,
Are the repositories you want to create a Pull Request between actually forks of each other? The two repos need to have a common ancestry for a PR to work.
cheers,
Tim
