It's been several times already where I have issues with the `@` in my READMEs on bitbucket
for instance, when writing SCSS documentation: the [at]import will be replaced by the name of some guy whose login is "import", which mess my code sample.
now I'm trying to write [at]npmLogin/project and I get another hyperlink.
I tried to escape the @ with a backslash with no success at all.
Can someone please tell me there is a workaround for this ?
Thank you
This might be a bug. Have you tried using backticks e.g. `@import` as a workaround?
seems to work, thank you
