×I have an new installation of Bitbucket, I was able to create a project, but right after the project was created, I could no longer open the project page. I haven't been able to figure out what is causing the issue, I did see some errors in the log files. Additionally I noticed that the ElasticSearch service will not start.
Hello Steven,
We’ve seen similar issues prior when a project is created but the path used is a temp path or a path with insufficient permissions for the service to access. The screenshot you included is a good example of the inability to access the directory.
With this said, could you please check the path you’re using for the repo and ensure the Bitbucket service account has the proper level of permissions. Additionally, ensure you’re not using a temp path and you’ve assigned a proper and accessible path for the project. Further information on this may be found at Running Bitbucket Server as a Windows service.
If you’re still having issues please reach out and let us know.
Stephen Sifers
Thanks Stephen, I was able to successfully fix this by making the user running Bitbucket the owner of the home directory. Thanks for your quick response!
Hello Steven,
Very happy to hear you're able to adjust the permissions for the directory and resolve your issue!
Stephen Sifers
