Bitbucket project security level i want to create 2 admin and both admin have different-different project and they can't do anything with the other project. such as i have 10 project with 2 admin A and B.
A have 5 project and
B have 5 project, now i want admin A can't do any thing with admin B's project and admin B can't do anything with admin A's project
How can i use project permission based on admin.
Kindly suggest for the same, its my client requirement
Asha
Hi Asha! Project permissions are added on a "per project" basis, so you can give someone Admin permissions for project A, but not for project B, and viceversa. To modify permissions for a project:
For more info you can read Using project permissions.
Let us know if you have any questions!
Best regards,
Ana
Thanks Ana!
But i want this restrictions based on Bitbucket admin not bitbucket project admin. as mention in this page the bitbucket admin can manage global permission and edit application setting Global permissions
My requirement is i have create 2 bitbucket admin and share some project to both and they don't do any thing in other project.
is it possible? if yes then please suggest.
Hi Asha, that won't be possible using the Global permissions, that's why we have the Project permissions specifically to cover that use scenario.
Ana
